TwinTurbo.NET: Nissan 300ZX forum - NDS isn't the true timing...
Subject NDS isn't the true timing...
Posted by Medallion Man on June 04, 2013 at 3:29 AM
  This message has been viewed 276 times.
In Reply To Re: so have you adjusted to IAA by the screw? posted by Da Flash on June 03, 2013 at 11:45 AM
Message you need to get a timing light to view the real timing.
mine showed a perfect 15 on Conzult, ecutalk and another program but that is what the ecu thinks not what the engine is actually set at.
you also have to make sure that in setting the IAA it isn't fully in out out as that isn't the way it is supposed to work and would indicate another issue.
